Forum: Old versions
Topic: Pro License
OK I will be going pro (purchasing the pro version) very soon but have a question. I have 2 controllers; A VMS 4.1 and a NS6. The VMS I use for mobile gigs and the Numark for larger dances and clubs/bars. Can I just use the one license (seeing that I only have one laptop with the software) Or will I be forced to purchase 2 licenses? There is only 1 laptop.
Thanks
geposted Fri 03 May 13 @ 12:27 am
You will only need one license. VirtualDJ Pro will work with all native supported controllers (You could even use both the VMS 4.1 and NS6 at the same time if you wanted to!)
You will need to change your sound settings appropriately though, depending on which controller you are using.
