Forum: Old versions
Topic: Help - Denon HC4500 & MBP 15
J-SnipPRO InfinityMember since 2006
How does one set up proper sound config for use with the Denon HC-4500?
Both decks play on outputs 1&2. In advanced config the only outputs showing up for the HC-4500 is Outputs 1&2. It's as if the MBP is not seeing outputs 3&4 from the HC-4500.
Am trying to give this a test run this weekend...so far im stuck on this part.
UPDATE ::::: disregard. Got it working thanks to the magic Wiki. I gave up searching for it on the site before posting this. I dug a little harder and found it .
geposted Fri 03 May 13 @ 9:08 pm
