Hi, One think that I think could be improved is the size of the automix point, sometimes if you miss the point the song jumps to the beginning or end and this can sound terrible, One way is make a small tab on the point to make it easier to use.
geposted Thu 09 May 13 @ 8:36 am
If you mean the "Cursor" point, then you will have to expand it from your os control panel, double click on your mouse icon, click the "pointer" tab and choose a different pointer scheme.
geposted Thu 09 May 13 @ 10:40 am
He must mean the "anchor" of the software, not the mouse pointer.
The anchor size depends on the skin. If the creator of the skin has created large anchors they will be easier to grab ;)
geposted Fri 10 May 13 @ 1:42 am
