can u give ur serial number ? maybe i have same serial number
geposted Thu 09 May 13 @ 9:27 pm
the way I got my VDJ Pro serial number was to use the numbers on the front of my credit card. If you have already done that then email support with details of your purchase and they will let you know. If you have lost your LE serial you need to contact the manufacturer to recover it.
geposted Fri 10 May 13 @ 2:13 am
Nobody will give you their serial number. Do not ask this again or your account will be locked.
If you like VirtualDJ, then please support the software and its future development by purchasing it: https://virtualdj.com/products/comparison.html (Especially if you are a working DJ and you are making money as a result of using it.)
If you have already purchased and have lost your serial number, please contact support: https://virtualdj.com/contact/
Please also use the correct forum when posting. This forum is for VirtualDJ plugins (Skins, effects, etc.), which are free to users who have purchased and registered the software.
geposted Fri 10 May 13 @ 4:28 am
