When I'm playing with Virtual DJ using headphones, on my laptop, music sounds great at any volume. As soon as I plug my 6000 into the laptop USB, changes setting to Asio, at even low volumes my music sounds like there's a loudness setting on even at low volumes. I have no other problems with Virtual. I'm not sure how to check the Asio settings. The only setting I see is Audio Buffer Size. The driver is 2.2.1
My laptop has had all the audio tweeks and like I said, Virtual DJ sounds great without the Denon.
Any help would be appreciated.
Greg
Greg
geposted Fri 10 May 13 @ 12:49 am
I've done a lot of research since posting my question. I made a few adjustments and sounds good now. I guess I expected some advice from the pros, but then I don't contribute here much....
geposted Sun 12 May 13 @ 12:26 am
This is a common problem, the Asio drivers don't work well on all machines and this had been covered many times hence the reason no one responded.
Keith
Keith
geposted Sun 12 May 13 @ 11:36 am
