Hi,
So I'm currently using VDJpro v7 and hercules RMX to broadcast a radio show and have had no end of trouble getting the set up I want, I have all but figured it out now, however, I have one last niggly problem and that is the mic attenuation.
It only appears to affect the signal going out of the console from output 1&2. I'm not broadcasting from that output, but rather from within VDJ itself (just using the console as a controller rather than a sound card), is there any way of getting VDJ to attenuate the music when the mic is turned on in VDJ?
geposted Thu 16 May 13 @ 4:49 pm
Please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
VirtualDJ doesn't have a mic talkover by default, but you could map a button that you don't use or a keyboard shortcut to the following:
down ? deck active volume 25% : deck active volume 100%
Adjust the values to suit your requirements if necessary. Press and hold the button while talking on the mic.
geposted Thu 16 May 13 @ 10:43 pm
