I just got a Numark N4 off of eBay, coming from a Mixdeck, and I have been trying and failing to set it up. Everytime I open up my version of Pro, 7.0.3, I can get it to play through the speaker, but I can't manipulate the program at all with the controller. The LE that came with it works, but it's missing the automatic playlist function that I really like and I can't change the four deck skin to a two deck skin.
Can someone offer me any help on making the N4 work on the current version of Pro I have? I would really appreciate it.
geposted Thu 16 May 13 @ 8:04 pm
v7.0.3 is an old and out of date version of the software. There have been many changes and improvements to the software since then (See http://www.virtualdj.com/wiki/VirtualDJ_History.html ), including native support for the Numark N4, which is not supported in older versions of the software - We are now on v7.4
Please register your serial number on your account http://www.virtualdj.com/users/edit.html and then upgrade to the latest version: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are a working DJ and are making money as a result of using it at your gigs.)
geposted Thu 16 May 13 @ 10:37 pm
