i would like reverb & echo fx to continue after the desk that is being used has been stopped. at the moment if you have reverb or echo selected on a track that is playing it stops when you stop that track which limits your mixing caplblitys
geposted Thu 23 May 13 @ 10:00 am
Hi there!
Try the EchoDoppler effect. I use it all the time just because it continues to echo after the track is stopped. I would like Atomix to add a post fader-feature of course but hopefully we will see that in version 8.
geposted Mon 27 May 13 @ 2:43 pm
config --> options --> disable effects reset on load
geposted Tue 28 May 13 @ 6:11 pm
