Forum: Old versions
Topic: A few questions
A few weeks ago i bought a Numark DJ2GO controller (http://prntscr.com/16cds9). Due to its limitations I needed to get a keyboard ( {My keyboard} http://prntscr.com/16ce2b)... Long story short, i have some issues trying to program it.
first I'm having a hard time selecting a certon color pfl. for ex. I want my right arrow key to select the red deak so I can then add loops, FX, Etc. ({Thi arrows} http://prntscr.com/16cf8l). it's getting really annoying only using one Pfl butten ({Plf} http://prntscr.com/16cifc)
next, How would i assign certon FX to certon buttons ( {FX buttens} http://prntscr.com/16cfn0)
and, What exactly is a bar ({BAR} http://prntscr.com/16cgam) and how would i program one of those sections of the bar to 4-8 certon keys
({certon keys} http://prntscr.com/16cgn3)
also, how would I make it so that when I push push F1 - F12 it would play sampler 1 -12 and when I pressed ESC + F1 - F12 It would record the sampler 1- 12 ({samp} http://prntscr.com/16chxc)
lastly, Is there a way to reprogram my Numark DJ2GO controller ({Numark DJ2GO controller} Numark DJ2GO controller)
Thanks soo much. I know its a lot but I really do appreciate the help.
-- DJ Glitch or untitled_01
geposted Thu 23 May 13 @ 5:33 pm
bump
Hi
First of all, none of your links work because there is an extra character ) at the end of each one.
Secondly, as you must already be using a computer to run VDJ (and the computer must have a keyboard) there was no need for you to add another keyboard. The VDJ software is already mapped for use with your existing computer keyboard.
The default keyboard mapping is here. Information on mapping is here.
