Hi guys can anyone offer advice on this for me please - I have a track loaded in deck A which is 21 minutes long but the wavebar is only showing the first bit of it. if I click on the wave say 10 mins into the track that bit of the wave appears but again not all of it - anyone got any ideas how to fix this please ?
Also whilst on the subject of waves is there a way of changing the colour of the main waves on the top of the screen or at least the colour of the cue point names as I'm finding them difficult to read as they are (Red & Blue)
I'm using the VDJ 7 2 Decks Skin !
Thanks Paul
Thanks Paul
geposted Fri 24 May 13 @ 8:19 am
goto config/performace and change "Don't Pre-load files more than" to infinite "You probabaly have it set for 10min".
geposted Fri 24 May 13 @ 8:28 am
Ahh as simple as that ! Many thanks for the solution ! any ideas on the other question on the wavebar colour?
geposted Fri 24 May 13 @ 8:37 am
I know you can turn it OFF thru the CONFIG.
If you need to change the color, it might be in the XML file of the SKIN you're using (I'm not sure).
Just make a copy of it play around with the copy.
geposted Fri 24 May 13 @ 11:25 am
Thanks I will give that a try
geposted Sat 25 May 13 @ 9:08 am
