So I have 2 versions of Virtual DJ installed on my laptop 1 is the Pro version and the other LE. Im not sure how LE got on here but i tried removing it and it also deleted my pro version.... I would I delete just the LE version without deleting my Pro?
geposted Fri 24 May 13 @ 8:33 pm
LE and Pro can be both installed at the same time and uninstalling one should not affect the other. Make sure that you answer NO to removing your database and settings when uninstalling.
We have no record of you purchasing VirtualDJ Pro (Which can only be purchased from our website), so if it is a copy that has been obtained illegally from elsewhere then it may not work correctly and may be why you are having problems. If this is the case, then please support the software and its future development by purchasing it (Especially if you are a working DJ and you are making money as a result of using it at your gigs.) Your VirtualDJ LE for DMC-2 entitles you to a discount off the cost of upgrading: http://www.virtualdj.com/buy/index.html
If you have purchased, then please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.htmla
geposted Sat 25 May 13 @ 2:34 pm
