hi
im currently using the free virtual dj and wondering if i can mapp the pfl keys to both be on like i can with djuced software
Can someone give me the codes to put in please :)
geposted Tue 28 May 13 @ 5:33 pm
You need to map one keyboard button as ..
deck 1 pfl
and another one as ..
deck 2 pfl
See here on how to map a keyboard button .. http://www.virtualdj.com/wiki/How%20do%20I%20map%20a%20keyboard%20shortcut.html
However, the default 2 Decks skin of VirtualDj will not show you when the decks are on PFL, as the buttons in the MIXER are assigned to show the selected deck (pre-listening only one deck at a time), so you will not have the visual of which deck is prelistened. The 4 Decks default skin will show that (different approach for pre-listening)
For pre-listening with Home Free version using a laptop with a single Audio Output, see here.. http://www.virtualdj.com/wiki/Pre-listen%20using%20headphones%20in%20VirtualDJ%20Home%20FREE%20or%20Broadcaster.html
deck 1 pfl
deck 2 pfl
geposted Wed 29 May 13 @ 12:35 am
sorry should have said im using hercules dj air mixer with built in soundcard.
i could use both before but something has changed now when i select pfl it acts as a select button for the effects :/
ive put the mapper from hercules on again but no change
geposted Wed 29 May 13 @ 1:29 am
The mapper is not available to unlicensed users, so you have most likely downloaded it from an illegal 3rd party source and may have an out-of-date version. You will also need to purchase the full VirtualDJ Professional to be able to use MIDI controllers.
If you like VirtualDJ then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
If you have already purchased then please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
Once registered, you can download Cioce's latest mapper pack from http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html - Please also read the notes about using it on the download page.
NOTE: The Hercules Air is not natively supported by VirtualDJ. If you need any detailed help/assistance with this mapper, please contact its author.
geposted Wed 29 May 13 @ 4:48 am
Sorry I don't think I wrote it clearly
On djuced I can use both pfl buttons together
On vdj I downloaded free home and also mapper from hercules
I can't use both pfl's in this
Yes of course id love to buy the pro but the trouble Im having now im a bit dubious about spending a couple of hundred pounds if it doesn't work.
geposted Wed 29 May 13 @ 5:14 am
Two deck controllers by default are normally mapped to select one deck at a time for PFL because for most users, being able to select more than one at a time is only normally necessary for 4 deck controllers.
On a 2 deck controller, without making any changes you can simply use the headphone MIX knob to adjust how much of the master you hear in your headphones (E.g: Adjust it to half way and you will hear both decks equally.) If the controller doesn't have a headphone mix knob, simply use a skin that does such as the default VirtualDJ 4 decks skins.
Alternatively, change the mapping for the PFL button on the controller from select to pfl
geposted Wed 29 May 13 @ 6:56 am
Lol ok thanks I sort of got that
Its for my teenage son and dads trying to set it all up which is making my brain hurt
geposted Wed 29 May 13 @ 7:00 am
