This is driving me crazy.
I'm attempting to access iTunes in order to access my playlists but iTunes is not showing up in my side browser. I went to 'preferences', 'settings', 'browser' and deselected everything except iTunes and everything was gone. iTunes is nowhere to be found. Can anyone help me??
Side note: I recently backed everything up onto an external hard drive which gave me problems with iTunes. All my iTunes music disappeared. I was able to get my music back from my hard drive but all of my playlists are gone now. I'm still working on getting them back but until then I have created some new playlists so that I can continue mixing. Now we arrive at the problem stated above. Can't find iTunes in the side browser.
geposted Wed 29 May 13 @ 8:00 pm
geposted Thu 30 May 13 @ 3:28 am
Hey thanks for the tip. So I followed the directions and it worked but now I have a Mac related problem....I guess. I'll ask the question here but I'll also post it on the Mac forum. If anyone can help that would be amazing!!
After transferring everything to the hard drive and it wiped my iTunes, every time I opened iTunes it would put 4 files onto my desktop (which had never happened before). The files are called: itunes music library.xml, itunes music library genious.itdb, itunes music library extras.itdb and itunes music library.itl .
Anyway, I started collecting the files in a folder and I ended up getting so many copies that I started to delete them. Once I got all my music back and noticed that my playlists were gone I put two and two together and realized what I had done. those files I deleted were my playlists. Any advice would be very helpful. I'm checking my hard drive to see if there's a copy on there but I'm not sure yet. fingers crossed!
Thanks in advance if anyone can help me with this.
geposted Thu 30 May 13 @ 9:34 am
I'm attempting to access iTunes in order to access my playlists but iTunes is not showing up in my side browser. The link above does not work.
geposted Sat 07 Jun 14 @ 8:26 am
Which version of Virtual DJ are you using (7 or 8)?
Have you moved the default location of the iTunes library? Normally it will be C:\Users\USER\Music\iTunes
If this is where it is then ensure you have iTunes available to your browser.
In version 8:
In version 7:
In version 8:
In version 7:
geposted Sat 07 Jun 14 @ 10:20 am
