I am using version 7, and have been with no problems up until this last week. Out of nowhere, now when i click on the icon to launch the software, it just sits on the splash/startup screen with the 'loading database' message. I really, really need to have things back to normal as soon as possible. Does anyone have any idea what to do?
Thanks so much,
Joe
Thanks so much,
Joe
geposted Sun 02 Jun 13 @ 9:13 pm
Try pressing ALT+TAB - There may be an error message that's popped up in the background, such as ASIO or WDM error if your sound settings are incorrect (If this is the case, click OK on it and then go into CONFIG -> Sound Setup once VirtualDJ finishes loading and check your settings.)
geposted Mon 03 Jun 13 @ 6:40 am
