Forum: Old versions
Topic: Pitch decreasing by itself (timecode vinyl)
Hi there,
I recently noticed a phenomenon I'm sure i haven't had before.
When I play a track using timecode vinyl the pitch decreases without any manipulation.
After playing a timecode vinyl end to end the pitch is at about -3% - every full play lessens the speed further.
By now I have changed EVERY element of the chain (vinyl - Serato vinyl and brand new VDJ vinyl , needle, turntable, interface, laptop), installed everything from drivers to VDJ freshly but nothing helped so far.
Since absolute mode works fine (but of course won't let me use cues which i need) I conclude VDJ gets an impulse from somewhere... - but how?
Before this came up, the pitch was constantly linked to the fader on my turntable, even after syncing by button.
Has anyone experienced this on tcv?
Does anyone have a hint on how to get rid of this issue?
geposted Tue 04 Jun 13 @ 1:54 pm
Update:
Interstingly, it works the other way, too.
Yesterday on a small gig, when playing a track the pitch sped up to >200%.
Last thing I forgot to change was the USB cable - as I ecpected that was not the solution.
OK, just in case someone cared:
Thanks to the Support Team I found out that I had "Disable Clear Sound" unchecked and obviously shouldn't have...
