i have a cortex dmix600 that i want to hook up to my computer
it has a usb connection to do so
but my computer needs a driver in order to recognize it as a turntable
where can i get a driver for that
i'd love to us it with virtual dj
geposted Tue 04 Jun 13 @ 3:37 pm
does this unit connect to a PC? looks like it only reads external storage devices like usb sticks and external HDDs.
http://www.musiciansfriend.com/pro-audio/cortex-dmix-600-digital-music-control-station
"Built around the same engine as the HDC-1000, the DMIX Series integrates the power of Cortex's patent-pending USB compatible technology and a 2-channel mixer into one compact, easy-to-carry, all-in-one digital mixing solution (only 12 lb.). Whether mixing at home, in the club, or at a party, the DMIX-600 delivers optimum functionality and control of your digital music files stored on an iPod, external hard drive, or USB flash drive that is perfect for portable setups, permanent installations and mobile DJ rigs."
geposted Tue 04 Jun 13 @ 3:38 pm
yes it has a turntable to PC port on the back of it
specifically labeled "PC" so i just figured it did
but it was used when i bought it so i don't have the CD it was supposed to come with
thus i am in need for a driver so my PC can recognize it as a turntable
i went online and saw other turntables also need drivers installed to the PC
so again i thought maybe that's what i need
geposted Tue 04 Jun 13 @ 6:12 pm
Unfortunately, the Cortex DMIX600 is a (discontinued) all-in-one stand-alone USB media player. It's not MIDI capable and not intended to be hooked up to a computer to control DJ software. It's for stand-alone media playback only without using a computer. The USB connector on the back is for plugging into a computer to allow you to use it as an iPod dock.
It also cannot be used with timecode because it lacks separate outputs for each of the decks to connect to a timecode sound card.
Your best option would be to sell it on eBay and use the money to purchase a MIDI controller. A similar product that also offers USB media playback as well as full MIDI controller support would be the Numark MixDeck series. Make sure that the controller that you purchase comes with VirtualDJ LE included, otherwise you will not be able to use it with VirtualDJ unless you purchase the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
A selection of other popular MIDI controllers can be found on our hardware page: http://www.virtualdj.com/products/hardware.html
geposted Wed 05 Jun 13 @ 4:50 am
The device you have is not a turntable.
Turntables look like this, and play records (aka vinyl):
geposted Wed 05 Jun 13 @ 6:18 pm
