Hi,
I have just bought the Hercules MP3 E" and it works great on the supplied software Virtual DJ DJC. What I cant find is how to use my iTunes Library on it. I have looked on the download centre and downloaded the latest version and that still doesnt have iTunes capabilities. Is there a way I can use iTunes on DJC and how can I do it?
Thanks
Thanks
geposted Wed 05 Jun 13 @ 1:08 pm
Itunes and VDJ are different products and do not use the same database.
While using VDJ you just can "read" iTunes playlists, if iTunes is installed by default.
If not, please have a look here:
http://www.virtualdj.com/wiki/Playlist%20Itunes%20not%20showed.html
BUT you can add without a problem your iTunes music folder to VDJ serachDB (select the folder - rightclick and add to serach dB)
After that please do the BPM scan to every unscanned track :-) and they should look great inside VDJ.
geposted Fri 07 Jun 13 @ 3:09 am
