ciao a tutti io possiedo una console stanton djc-4 e uso virtual dj pro...il mio intento sarebbe di registrare la mia voce con un microfono collegato all'aux della console facendola passare su un piatto per poi mixarla con la base....il problema è che il microfono si sente molto basso e la voce non si sente quasi....la mia domanda è:c'è qualche impostazione su vdj per aumentare il volume del mic in entrata?, o sto sbagliando qualcosa nel collegamento del mic?
la cosa che mi fa innervosire è che ero riuscito a risolverlo questo problema, poi però non ho usato la console per un po' di tempo e adesso no mi ricordo più come avevo fatto..
grazie mille
grazie mille
geposted Sun 09 Jun 13 @ 4:53 am
This is a Forum for English language messages only. Please post your question again in English or post in the Italian Forum.
geposted Sun 09 Jun 13 @ 8:46 am
hello I own a console stanton djc-4 and use virtual dj pro ... my intent would be to record my voice with a microphone connected to the aux of the console by passing it on a plate and mixing it with the beat .... the problem is that the microphone feels very low and the voice is not heard nearly .... my question is: Is there any setting to vdj to increase the volume of the mic input?, or am I doing something wrong in connecting the mic?
the thing that makes me nervous is that I was able to solve this problem, but then I did not use the console for a bit 'of time and now Ii don't remember how I did ..
thank you very much
thank you very much
geposted Sun 09 Jun 13 @ 11:56 am
Please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
If the mic volume is very low then it could be the wrong impedance for the controller. Try using a different mic.
A knob mapped to mic_volume can be used to adjust the input level. The controller and/or skin should already have a knob to be able to adjust this. If not, try using a different skin such as the default VirtualDJ v7 4 deck skin.
geposted Sun 09 Jun 13 @ 12:14 pm
