1st. I tried searching NS7 and I got "No result found..."
I plug everything in and start VDJ Pro 7. If the FX bar is plugged in it messes up the headphone settings. Like the master volume bleeds louder than the Cue (PFL) volume. Or the channel volume slider controls the headphone volume. Sometimes this doesn't happen but most of the time the results are the same. Is there a plug in/ turn on pattern I'm missing? Thanks, and sorry if this has already been posted, I tried searching first w/ no results.
HP Pavilion DV7
Intel i5
6 GB ram
Windows 7 64-bit
Numark NS7FX
VDJ Pro 7.4
HP Pavilion DV7
Intel i5
6 GB ram
Windows 7 64-bit
Numark NS7FX
VDJ Pro 7.4
geposted Sun 09 Jun 13 @ 11:58 am
I see there are two separate native mappings in the latest VDJ Pro - NS7 and NSFX (presumably that's supposed to be NS7FX).
In theory then, VDJ should use the NSFX mapping when you run it with the FX bar already in place. If you run it with just the NS7 connected then it would use the other mapping, and possibly not switch if you add the FX bar afterwards.
geposted Sun 09 Jun 13 @ 1:35 pm
