Hello everyone,
i used this line:
deck # hot_cue 1 ? down ? deck # goto_cue 1 & deck # play & set 'flash_#' 1 : var 'through_#' 1 ? nothing & set 'through_#' 0 & set 'flash_#' 0 : deck # pause & deck # goto_cue 1 & set 'through_#' 0 & set 'flash_#' 0 : deck # set_cue 1
in the mapper but i want it to play after 2 seconds, how do i do this.
Also when i try to map my vci 100 to virtual with loop half and loop double, only 1 works.
i used this line:
geposted Tue 11 Jun 13 @ 5:57 am
that was an old workaround you don't really need to use it anymore. using 'cue_play 2000ms' should do the same thing. you don't even need to specify the time, that is just to show you that you can
geposted Tue 11 Jun 13 @ 7:33 am
Does it work on all 4 cue's? and how do i define that?
Do you know about the loop section error too?
I ment it like a sample.
Press 1 on play's directly until i let loose or the 2 second rule
press 2 play cue 2.
but now it overwrithes cue one
press 2 play cue 2.
geposted Tue 11 Jun 13 @ 7:42 am
cue_play 4 2000ms
what type of control is on the vci, buttons or encoder
geposted Tue 11 Jun 13 @ 7:50 am
Buttons
Now it just overwrites the cues.
Its more like a sample thing.
I place the cues, and press cue 1 or 2 or 3 and it jumps to that cue and play's no more no less :P
geposted Tue 11 Jun 13 @ 7:53 am
I don't think it's possible to map holding for two seconds the traditional way, but test something like this to see if it could work, I can't as I'm on an android tab.
goto_cue 1 & play & holding 2000ms ? nothing : stop & goto_cue 1
all the other stuff can get added in later but this is the important bit.
also I should mention that the script you are using was designed to allow play through by hitting the play button when a cue is being held, at the time of writing it that functionality was not standard, it is now though.
loop controls should just be
loop_select +1
loop_select -1
loop_select +1
loop_select -1
geposted Tue 11 Jun 13 @ 8:11 am
Nope doesnt work.
First one plays on and on. Doesnt really sample or temporary play.
last one does nothing
geposted Tue 11 Jun 13 @ 8:16 am
anyone else got an idea? can i combine keys? Like go to cue 1 deck 1 + cue_play 1 deck 1 ms2000?
Dont know if it is the right code ;)
geposted Wed 12 Jun 13 @ 9:21 am
