Whats up everyone,
I was wondering how to get my external mixer to work with vdj on macbook pro to be able to broadcast on VDJ Radio.
I have tried deleting the advanced config from the audio/midi in the utilities and start over.
Advanced config is as follows:
Deck 1---Numark DJ/IO---output 1&2
Deck 2---Numark DJ/IO---output 3&4
Record Loopback---USB Audio CodeC--input 1&2
When I then click on OK I get the error message Error in the sound driver of CoreAudio. Your sound card is probably not connected or the settings are incorrect.
As mentioned above I have tried to delete the Virtual DJ Advanced in the audio/midi and start over and still to no avail. Have reinstalled my Numark DJ/IO driver. I did notice that with just the numark djio and no record loopback will work correctly when not broadcast but when i do broadcast i can hear when im cueing. I have tried with PC and works like it should just PC is an Old laptop and would like to use my Mac.
An advice would be much appreciated.
Charlie C
Charlie C
geposted Fri 14 Jun 13 @ 6:52 pm
