Hello i bought a American Audio VMS2 mix board and its work great up till about a month ago when my left jog wheel quit working on me it doesn't matter if im in scratch or other setting it does stop if you stop wheel while song is playing and to cue is next to impossible it takes about 150 spins just to move the start a very small amout compared to right side which joggs perfect is my board getting old or is there a possible way to try to fix it cause it almost seems like its not programed right but everything ellles on board works 100% to my knowledge
geposted Sat 15 Jun 13 @ 7:10 am
Do a clean installation of the VirtualDJ LE software following this page .. http://www.virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
If the issue is still present, then most likely its a hardware issue, and you need to contact with American Audio.
geposted Sat 15 Jun 13 @ 8:56 am
