Can anyone tell me if I need a preamp to use a mic with my vms4.1. Tried with and with out and still not getting any sound.
geposted Mon 17 Jun 13 @ 8:19 pm
The VMS 4.1 has two mic inputs on the front panel. These can be used for mics. Nothing else is needed.
Plug a mic in, turn up the mic volume, turn up the master volume. The sound comes out of the master outputs.
geposted Tue 18 Jun 13 @ 4:34 am
... and make sure you're using a dynamic mic. If your current mic is a condensor-mic it will need phantom power, something your VMS doesn't provide.
geposted Wed 19 Jun 13 @ 3:36 am
Good point! Also, make sure you're using a mic designed for DJs and/or singers, not a computer mic. Computer mics are not suited to DJ use.
geposted Wed 19 Jun 13 @ 6:14 am
Damn! I've been using a condenser, no wonder it wasn't working. Thanks for your help.
geposted Wed 19 Jun 13 @ 9:59 pm
YW.
If you want to use that mic, you can add a external phantom power supply. Something like this: http://www.amazon.com/Seismic-Audio-SA-PPCM-Condenser-Microphones/dp/B00BL8VXWE/ref=sr_1_15/189-0330700-3916213?s=musical-instruments&ie=UTF8&qid=1371740428&sr=1-15
geposted Thu 20 Jun 13 @ 10:02 am
