I have had my mk4 for a while now and have some questions. I am running two vinyl tables and the mk4. Is there a way to reverse the crossfader? aka hamster style. And is it possible to have the jog wheels act as another "set of turntables like having 4?
geposted Thu 20 Jun 13 @ 10:29 pm
If I remember correct, there is an option to activate hamster mode through the registry tool.
You can download it after you registered your copy of VDJ Pro Full here: http://www.virtualdj.com/users/edit.html
geposted Fri 21 Jun 13 @ 4:52 am
No registry changes are necessary. Simple upgrade to the fulll VirtualDJ Pro at a discount and then map a button or a key on your keyboard to the action: crossfader_hamster
Some custom skins may also have a button to toggle this.
In the full Pro, you can also use a 4 deck skin and map a button on your MK4 to toggle between the decks: http://www.virtualdj.com/wiki/Control%204%20decks%20with%20a%202%20deck%20controller.html
geposted Fri 21 Jun 13 @ 11:41 am
