Greetings everyone-
First time posting.
Just purchased an American Audio Encore 2000. Having trouble getting it to play with VDJ. I have downloaded the drivers & I already have VDJ Pro. American Audio site & manual is useless. Can anyone help me config VDJ to get it to work?
Thanks!!!!!
First time posting.
Thanks!!!!!
geposted Sat 22 Jun 13 @ 4:46 pm
Page 11 of the Manual...
You should be able to see .. MIDI on the display of the unit.
Launch VirtualDj and check that the unit is properly detected (in CONFIG-->Mappers tab )
The Sound Setup in the first tab of CONFIG should be ..
Inputs.--> None
Outputs.-->Headphones
Sound Cards. -- >ASIO and next to that ..choose ADJ Encore ASIO (or similar)
I dont own the unit, so your feedback would be useful for our wiki pages.
manual wrote :
14. SOURCE SELECT BUTTON - This button lets you toggle between USB Port 1, USB Port 2, & CD player.
This selector lets you choose which source will play on either side. The corresponding LED's located above
the button will verify which source is active. The source selection can only be done in PAUSE mode. Press this
button down for at least 3 seconds to enable MIDI on the corresponding deck. Press this button again
for at least 3 seconds to disable MIDI.
Inputs.--> None
geposted Sun 23 Jun 13 @ 5:10 pm
Thanks for the reply!
Sometimes it's those little tweaks that make the difference.
Set the unit to MIDI before starting VDJ.
On the CONFIG tab, I had to set the Outputs to - External Mixer.
I know it's not a "true MIDI" controller because you can't see all of the knobs & dials move in VDJ, but I still the
functionality of VDJ - playlists, sidelists, etc. I'm happy!
Again, thank you for your help!
geposted Sun 23 Jun 13 @ 7:46 pm
hmmm thats strange.. Are you sure about that ? The default mapper shows that the unit has a real midi mixer so it should work as Outputs-->Headphones.
geposted Mon 24 Jun 13 @ 9:19 am
Yep I'm sure. Putting it on headphones only one side worked.
geposted Mon 24 Jun 13 @ 10:57 pm
should have also said that the headphones setting causes channel 2 to bleed into channel 1.
geposted Tue 25 Jun 13 @ 5:37 pm
That's fine. We appreciate your feedback. We created a wiki page with the above information, for all Encore 2000 users... http://www.virtualdj.com/wiki/Encore%202000.html
geposted Wed 26 Jun 13 @ 12:27 am
the virtual dj le has less feature that i got from american audio encore 2000 the effects are less only if u pro upgrade it buy paying money there has to be some good features able to download for freee
geposted Mon 18 Jul 16 @ 1:58 pm
hello i have problem with american audio it say midi error how i fix it?
geposted Tue 18 Apr 17 @ 5:46 pm
Thats not entirely true as I have managed to programme every button, fader and led on the Encore 2000 to work with Virtual DJ as a full controller
geposted Mon 04 Dec 17 @ 7:42 pm
Please any here who have the softwear and midi driver of maerica audio encore 2000
geposted Sat 11 Aug 18 @ 7:56 am
Link to drivers and other Encore 2000 files https://www.adj.com/encore-2000 (Downloads tab)
geposted Sat 11 Aug 18 @ 1:27 pm
hello
geposted Sun 27 Jan 19 @ 5:18 am
Would love to see your mapping for the Encore 2000
geposted Fri 01 Nov 19 @ 12:16 pm
Would love to see your mapping for the Encore 2000 to
geposted Mon 20 Jan 20 @ 6:56 pm
