2 add:
- Search replace
- Search for string and add a marker in the tree to mark the mappings where the string is found
- Search replace
geposted Thu 04 Jul 13 @ 6:46 pm
Just downloaded the new version... I like what you did with the syntax highlighter, in no longer has to redraw after every character input which was causing it to flash, now it seems more responsive.
I'm not seeing where we can use find and replace, I tried [ctrl + f] and [ctrl + h] in all four sections but no love.. Also my edit menu is dulled out and inaccessible.
geposted Fri 05 Jul 13 @ 12:56 am
nono, this was an emergency bugfix for reloading the code after editing. Search repleace is up in my wishlisdt
geposted Fri 05 Jul 13 @ 1:19 am
The performance is smthing ill look at eventually, ill need to overwrite standard redraw routines, that will be a bit of a bitch
geposted Fri 05 Jul 13 @ 1:20 am
I'm not sure you need to keep worrying about the performance, it is running great on my PC at the moment.
geposted Fri 05 Jul 13 @ 1:57 am
I was just thinking...
//comments would be cool aswell
the regex for it is
if(string.match(/\/\/.*$/)){
string.replace(/\/\/.*$/, /[$&$&]/);
**It's using forward slash delimiters**
the regex for it is
geposted Fri 05 Jul 13 @ 4:11 am
the regex for it is
the regex for it is
Does VDJScript itself support comments?
geposted Fri 05 Jul 13 @ 1:31 pm
no unfortunately it doesn't
geposted Fri 05 Jul 13 @ 1:54 pm
mmm yeah that difficult than, right now I dont store the editor text, I only convert it on the fly and convert it back. But i'll think of something ;)
geposted Fri 05 Jul 13 @ 2:13 pm
sup JB.. I have been playing with your app, another issue I am having is I cant use [TAB] to format my scripts nicely, and it wont auto format until you exit the program and reload.
geposted Sun 07 Jul 13 @ 2:36 am
