Forum: VirtualDJ Plugins
Topic: Where's my plugin window?
khourigHome userMember since 2013
I create a window in the OnGetUserInterface function. In the debugger, I can see the messages arriving at the window, but my window never appears on screen.
I tried creating a test app that loads the plugin the same way that VDJ does, and I get the plugin window that I expect.
geposted Sun 07 Jul 13 @ 10:52 pm
You did pass the handle back to VDJ right?
geposted Mon 08 Jul 13 @ 9:09 am
Yes I returned the window handle. I'm not using MFC, just register a window class and create the window. I'm passing all messages to DefWindowProc except WM_CREATE where I'm saving that extra CreateWindow lparam with SetWindowLongPtr, which I reserved space for when registering the window class.
Someone is pumping messages to my window, including hiding it, because from the debugger I can see these messages arriving.
Could it be because I'm using the Home Free version? If so, what level of VDJ do I need?
Thanks for your attention.
geposted Mon 08 Jul 13 @ 11:31 am
Post up the relevant code and I will have a quick look.
geposted Mon 08 Jul 13 @ 11:47 am
Ok here's the code.
virtual HRESULT __stdcall OnGetUserInterface( HWND *hWnd )
WNDCLASS wc_info;
memset( &wc_info, 0, sizeof( wc_info ) );
wc_info.style = CS_HREDRAW | CS_VREDRAW;
wc_info.lpfnWndProc = WindowProc;
wc_info.cbClsExtra = 0;
wc_info.cbWndExtra = sizeof( this );
wc_info.hInstance = IVdjPlugin::hInstance;
wc_info.hIcon = 0;
wc_info.hCursor = 0;
wc_info.hbrBackground = (HBRUSH)( 1 + COLOR_WINDOW );
wc_info.lpszMenuName = nullptr;
wc_info.lpszClassName = "RemoteDJ_WndClass";
RegisterClass( &wc_info );
*hWnd = CreateWindowEx( 0, "RemoteDJ_WndClass", "Remote DJ", WS_CAPTION | WS_SYSMENU | WS_VISIBLE, 0, 0, Width, Height, 0, 0, IVdjPlugin::hInstance, this );
return NO_ERROR;
LRESULT CALLBACK WindowProc( HWND hwnd, UINT msg, WPARAM wparam, LPARAM lparam )
switch (msg)
case WM_CREATE:
LPCREATESTRUCT cs = (LPCREATESTRUCT)lparam;
SetWindowLongPtr( hwnd, 0, (uintptr_t)cs->lpCreateParams );
return 0;
return DefWindowProcA( hwnd, msg, wparam, lparam );
Using Window Spy, I see that VDJ has reparented my window. If VDJ ever decided to make that new parent window visible, my window would be visible within it.
Since I'm writing a generic plugin, how can I ever see the UI for it? For effects, DSPs, video plugins, they can be selected in the effects tab. I don't see my plugin mentioned anywhere. In some screen shots I see an "Others" tab that I don't have.
When I didn't give the window handle back to VDJ, I had a free floating window around, like I initially expected, but since there was no parent/child relationship between them, the main VDJ window kept getting in front of mine.
geposted Mon 08 Jul 13 @ 11:55 pm
If you are writing a 'generic' plugin, presumably against the IVdjPlugin class rather than one of the more specific classes, then you'll need Virtual DJ Pro Full for it to function correctly - as you have seen you are missing the 'Others' section in plugin which is where these appear.
I would guess this is why your window will never be shown by VDJ - because that section isn't present.
I wouldn't rely on the function of this class of plugin in anything other than Pro Full.
geposted Tue 09 Jul 13 @ 8:49 am
Hm. As I suspected. Thanks again!
geposted Tue 09 Jul 13 @ 10:45 am
