Forum: Old versions
Topic: Audio only left side (both internal and USB)
ewitlesPRO InfinityMember since 2006
As stated above... I have verified the audio devices to in fact work. But for some silly reason, VDJ is only playing on the left side. Using single card internal mixer.
geposted Sat 13 Jul 13 @ 8:02 pm
RobRoyPRO InfinitySenior staffMember since 2012
Can you post your sound settings ?
geposted Sun 14 Jul 13 @ 1:43 pm
Me thinks the problem is a DJ2GO. Apparently, it forces split mono in some weird way.
Is there a way to disable that feature?
geposted Sun 14 Jul 13 @ 2:04 pm
How can it force split mono? It has no audio interface.
In fact I'll check.....
OK I just plugged my DJ2GO in, started VDJ and the sound setup is exactly as it was - no split mono.
geposted Sun 14 Jul 13 @ 4:40 pm
Well, I just know that it will only play sound from the left side - two PCs running latest VDJ 7.
And the only way to remedy that was use advanced and manually assigned each channel.
Need to play again this week.
geposted Sun 14 Jul 13 @ 9:26 pm
any chance your speakers or the cord to your speakers are bad?
geposted Mon 15 Jul 13 @ 9:11 am
Think I know the problem. Sound settings - not connecting the controller.
Operator error. Nothing to see here - just move along. :)
geposted Mon 15 Jul 13 @ 5:45 pm
