i recently bought a macbook pro (first mac ever) and i having some issue when playing. when i am mixing two songs together and i try to search for a new song the program stutters and the song that im at that time playing glitches and stutters. im really at a loss with this. any idea what could be causing this to happen?
geposted Tue 16 Jul 13 @ 9:41 pm
What soundcard do you use?
I believe the Mac buildin soundcard, right?
These type of soundcards are good enough for use with iTunes or any other simple player.
But they are lost most the time when using a prof. DJ software like VDJ.
Please also have a look here:
http://www.virtualdj.com/wiki/Common%20Mac%20Performance%20Issues.html
geposted Wed 17 Jul 13 @ 2:31 am
i use two dif externals sound cards depending on which system in using that day. a denon 4500 and a denon 6000. it happenes when i use the internal or the two external sound cards
geposted Wed 17 Jul 13 @ 1:18 pm
The HC4500 and MC6000 soundcards are great soundcards and they will do the job.
But the internal is the problem ;-)
What do you mean with this?
Do you use them both at the same time?
djmike76 wrote :
.... or the two external sound cards
geposted Wed 17 Jul 13 @ 2:04 pm
No I do not use them both at the same time. I have two separate sound systems depending upon which one I use will tell me if it's going to be the 4500 or the 6000. When I do use it with either one of those external soundcards I still run into the same issue. Could it be a latency tweek?
geposted Wed 17 Jul 13 @ 3:15 pm
If you try to use a too low latency, then yes!
Just try to use a higher one in small steps and then have a look what happen.
On Mac side in combination with the MC6000 i noticed it will work better when you use the Advaced Stretching.
Please also check Denon side for the latest Firmware updates for the 4500 and 6000.
Maybe this also is part of the problem.
Beside of that please check this too!
http://www.virtualdj.com/wiki/DN-HC4500.html
http://www.virtualdj.com/wiki/DN-MC6000.html
geposted Thu 18 Jul 13 @ 2:29 am
I think i figured out my issue. i think it was my external hard drive. i was using a seagate 4tb and the speed of that hard drive wasnt fast enough for this comp. i bought a lacie 4tb thunderbolt external 7200 speed (i think thats the correct number) and since then i havent noticed the issue. the real test will be this weekend. i you let you know. thanks for helping
geposted Mon 22 Jul 13 @ 7:49 pm
Ok so the hard drive wasn't the answer however I can now safely say I have the answer. Config - performance - advanced stretching needs to be clicked. That resolved my issue. I hope this info will help someone somewhere done the road. It took me a month of tweaking but that indeed resolved the stutter when searching while two decks were playing at the same time
geposted Mon 29 Jul 13 @ 9:38 pm
geposted Tue 30 Jul 13 @ 2:15 am
