i have numark n4 and vdj pro 7.05
it was working fine for almost a year, all of sudden all the knobs went crazy (high, mid, low, gain, pitch fader) it just go up n down, left n right for no reason, basically it just went crazy. so i uninstall and reinstall it again, still doing the same crazy thing but now worse because i cant even open "ASIO config" and everytime i try to open vdj it keep saying "not enough channel" and the second window was "your soundcard is probably not connected or the setting incorrect". anybody can help me with this BS non sense?
Thank you
Thank you
geposted Sat 20 Jul 13 @ 8:07 pm
Definitely a hardware issue. Try to use a different USB cable, and if the issue is still present, contact Numark.
geposted Sat 20 Jul 13 @ 8:32 pm
okay, i dont know how but i fixed the stupid asio problem.but i still have the crazy knobs problem. when the volume is all the way down (off) everything looks normal but when the volume is up, start going crazy again (gain, high, mid, low, and pitch fader)
geposted Sat 20 Jul 13 @ 8:33 pm
Did you contact Numark?
You'll need to be more specific than "it goes crazy" for anyone to understand what might be happening.
Also, what exactly is the "it" that's going up and down, left and right?
geposted Sun 21 Jul 13 @ 6:47 am
Please do not post the same message or question more than once.
You have already asked this question and posted a link to a video of the problem in the Numark products technical support topic, where you can find an answer: http://www.virtualdj.com/forums/107208/Hardware_Technical_Support/NUMARK_Hardware_Products_%28Setup__Solutions__Fixes__Issues__etc_%29.html
[Duplicate topic closed]
geposted Sun 21 Jul 13 @ 11:30 am
