Is it possible to use the ION imx05 in virtual dj ?
geposted Wed 31 Jul 13 @ 7:20 am
I would like to say no, because i haven't read something about Midi in the description.
If it has MIDI, then it should work with VDJ PRO FULL after you have created a special mapping.
Please have a look here to see all actual native supported controllers by Pro Full.
http://www.virtualdj.com/wiki/VirtualDJ%20Controllers.html
geposted Fri 02 Aug 13 @ 2:32 am
Even if it does work (which it probably will as a basic stereo audio interface) it's not going to be much use for DJing.
It only has one volume fader, one bass knob and one treble knob. For DJing you really need TWO of everything (at least).
Ideally each deck should have its own volume, bass, middle, treble and gain controls.
geposted Fri 02 Aug 13 @ 6:19 am
Yes it will work as an audio interface.
geposted Thu 15 Aug 13 @ 4:23 am
