So I may purchase this little device because it's completely wireless, colorful, and you can really interact with people not behind the booth. Is there a mapping for VDJ yet? Thanks!
geposted Tue 06 Aug 13 @ 8:50 am
You posted about this a couple of days ago in another thread, where I mentioned that Numark claim to be working on it.
As you should be able to see from the Orbit product page on the Numark web site, there is no VDJ map available yet.
There is also no map here in the controllers download area.
If you check the Numark community site, you'll find people there asking for it too, with the same response.
Short answer - no!
Short answer - no!
geposted Tue 06 Aug 13 @ 9:05 am
Short answer - no!
Short answer - no!
Sorry about that. I don't remember posting something along these lines. Also, I do check Ozone (the Orbit's page for maps), I was just thinking maybe somebody on here has mapped it personally.
geposted Tue 06 Aug 13 @ 9:12 am
Have you seen this?
http://www.youtube.com/watch?v=k4JA3cKEF_c
geposted Tue 06 Aug 13 @ 9:22 am
Here is what I started with mapping the orbit to VDJ. When I finish I will post more.
Hope this help
Key / Action
0-37 / Deck 1 cue_stop
0-36 / Deck 1 play_button
0-38 / Deck 2 cue_stop
0-39 / Deck 2 play_button
0-40 / Deck 1 sync
0-43 / Deck 2 sync
0-CC1 / crossfader
0-41 / Deck 1 hot_cue 1
0-42 / Deck 2 hot_cue 1
0-44 / Deck 1 hot_cue 3
0-45 / Deck 1 hot_cue 2
0-48 / Deck 1 hot_cue 4
0-49 / Deck 1 hot_cue 5
0-46 / Deck 2 hot_cue 3
0-47 / Deck 2 hot_cue 2
0-50 / Deck 2 hot_cue 4
0-51 / Deck 2 hot_cue 5
Hope this help
Key / Action
0-40 / Deck 1 sync
0-43 / Deck 2 sync
0-CC1 / crossfader
geposted Sat 31 Aug 13 @ 11:34 am
Here is a map ive made with my Orbit.
*Note* This map is designed for a 4 deck skin. Also, some of the effects parameters may need changed as the effects ive mapped you may not have.
Feel free to offer suggestions, changes, comments, or ideas.
0-36 deck 1 play_button
0-38 deck 2 play_button
0-37 deck 1 pause_stop
0-39 deck 2 pause_stop
0-40 deck 1 sync
0-41 deck 1 pitch_reset
0-42 deck 2 sync
0-43 deck 2 pitch_reset
0-44 browser_scroll -1
0-48 browser_scroll +1
0-45 deck 1 load
0-46 deck 2 load
0-47 playlist_add
0-49 browser_window
0-50 browser_folder
0-51 browser_enter
0-CC1 deck 1 level
0-CC2 deck 2 level
0-CC3 deck 3 level
0-CC4 deck 4 level
1-48 deck 1 effect "backspin" active
1-50 deck 2 effect "backspin" active
1-49 deck 1 effect "beatbreak" active
1-51 deck 2 effect "beatbreak" active
1-44 deck 1 effect "DFV Flanger" active
1-46 deck 2 effect "DFV Flanger" active
1-45 deck 2 effect "Flanged LoopOut" active
1-47 deck 2 effect "Flanged LoopOut" active
1-40 deck 1 effect "echo" active
1-42 deck 2 effect "echo" active
1-36 deck 1 effect "FlippinDouble" active
1-38 deck 2 effect "FlippinDouble" active
1-37 deck 1 effect "Forward_Reverse" active
1-39 deck 2 effect "Forward_Reverse" active
1-CC1 effect slider +1
1-CC2 effect slider +2
1-CC3 effect slider +3
1-CC4 effect slider +4
2-36 deck 1 loop_in
2-38 deck 2 loop_in
2-37 deck 1 loop_out
2-39 deck 2 loop_out
2-40 deck 1 loop_half
2-41 deck 1 loop_double
2-42 deck 2 loop_half
2-43 deck 2 loop_double
2-CC1 deck 1 gain
2-CC2 deck 1 eq_high
2-CC3 deck 1 eq_mid
2-CC4 deck 1 eq_low
3-CC1 deck 2 gain
3-CC2 deck 2 eq_high
3-CC3 deck 2 eq_mid
3-CC4 deck 2 eq_low
3-36 crossfader 0% while_pressed
3-40 crossfader 50% while_pressed
3-47 crossfader 100% while_pressed
2-48 sampler 1 play_stutter
2-49 sampler 2 play_stutter
2-50 sampler 3 play_stutter
2-51 sampler 4 play_stutter
2-45 seek -4
2-45 seek +4
0-CC10 master_volume
0-CC9 crossfader
Thanks
-J. Loops
0-40 deck 1 sync
0-42 deck 2 sync
0-45 deck 1 load
0-46 deck 2 load
0-47 playlist_add
0-49 browser_window
0-50 browser_folder
0-51 browser_enter
0-CC1 deck 1 level
0-CC2 deck 2 level
0-CC3 deck 3 level
0-CC4 deck 4 level
2-36 deck 1 loop_in
2-38 deck 2 loop_in
2-CC1 deck 1 gain
2-CC3 deck 1 eq_mid
2-CC4 deck 1 eq_low
3-CC1 deck 2 gain
3-CC3 deck 2 eq_mid
3-CC4 deck 2 eq_low
2-45 seek -4
2-45 seek +4
0-CC9 crossfader
Thanks
-J. Loops
geposted Wed 18 Sep 13 @ 4:30 pm
Wow J. Loops! I completely forgot about this thread, and came back to the VDJ forums today to check what was going on and saw my old thread. Thank you for putting the time and effort into mapping this device, as I cannot map yet. Once again, thank you! :)
geposted Sun 22 Sep 13 @ 9:19 pm
I am still struggling to map this correctly. i cant get it to switch from deck to deck mostly. help or advice please and thank you
geposted Wed 26 Feb 14 @ 6:35 pm
if you register VDJ Pro there is a full definition and mapper available that controls the leds from VDJ not just the hardware, so you can get more feedback from VDJ..
geposted Wed 26 Feb 14 @ 7:02 pm
i just want to know which command it is to go from track to track and how jay setup deck 1 deck 2scenarios
geposted Thu 27 Feb 14 @ 8:23 pm
Hi, I am struggling to find all of the effects in vdj pro which come preloaded, flanger strobe etc, do you have a mapping list as vdj haven't replied, also for the x and y buttons
geposted Mon 30 Nov 15 @ 8:52 am
The Orbit has the following Effects mapped.
PAD1_BANK3 : Backspin
PAD2_BANK3 : FlippinDouble
PAD3_BANK3 : reverb
PAD4_BANK3 : Beat Grid
PAD5_BANK3 : flanger
PAD6_BANK3 : echo
PAD7_BANK3 : phaser
PAD8_BANK3 : distortion
VirtualDJ 8 comes with these native effects (in case you need to replace any of the above)
PAD3_BANK3 : reverb
PAD6_BANK3 : echo
PAD7_BANK3 : phaser
geposted Mon 30 Nov 15 @ 10:57 am
Would anyone be willing to share their Orbit Editor mapping files for VDJ?
Looking for basic functionality: [2 Decks + Mixer + Effects + Library]
...OR...
4 Deck A/V setup: [2 Audio + 2 Video + Mixer + Effects]
Any help is appreciated! :)
...OR...
geposted Sun 17 Apr 16 @ 5:41 am
