I believe it would be a good recommendation for future builds to consider giving the option of where to put the cache folder. Putting the entire program on another drive is not a very flexible option. If, for example, if you wanted to put your program on your C: drive (SSD) and put cache/data folder on E: drive (2/3/4 TB HDD), then they setup would be much more efficient...
geposted Thu 22 Aug 13 @ 11:58 am
You can specify the location for your Home Folder already, which contains the cache folder and a few others. A utility to do this is available to Pro Full users.
Alternatively you can move the files yourself to a different folder, they don't have to live in the cache folder.
geposted Thu 22 Aug 13 @ 3:18 pm
