Hey all,
I am a newbie here. I just managed to create and compile a basic plugin in a form of dll. My problem is how to load it on the actual software (Virtual DJ) in order to test whether or not it works.
Many thanks,
Alou
Many thanks,
Alou
geposted Fri 06 Sep 13 @ 1:54 pm
/users/username/my documents/virtualdj/plugins
pick which type of plugin fron those folder displayed.
geposted Fri 06 Sep 13 @ 2:55 pm
Hi,
Thanks for the help. I ve tried to put the DLL in the all those folders but seems like it is not working. A text file is supposed to be created when I load a track, if I understood right. Here is my class. It s quite simple, just for testing:
#include "vdjPlugin.h"
#include <stdio.h>
class PluginTest : public IVdjPlugin
public:
HRESULT __stdcall OnLoad();
HRESULT __stdcall DllGetClassObject(const GUID &rclsid,const GUID &riid,void** ppObject)
*ppObject=new PluginTest();
return NO_ERROR;
HRESULT __stdcall PluginTest::OnLoad()
FILE * pFile;
pFile = fopen ("C:\\test.txt","a");
if (pFile!=NULL)
fputs ("Blablabla\n",pFile);
fclose (pFile);
return S_OK;
Thanks again
#include <stdio.h>
public:
return NO_ERROR;
FILE * pFile;
if (pFile!=NULL)
fclose (pFile);
return S_OK;
Thanks again
geposted Sat 07 Sep 13 @ 9:38 am
A couple of things:
* VDJ Pro Full is required for use of the IVdjPlugin class rather than a subclass.
* These types of plugin go into Plugins\Other and show up under Effects > Others in VDJ.
* Your OLE COM entry point (DllGetClassObject) does not check the CLSID or IID.
* You need to implement the Release method to clean up after the memory allocation you made in DllGetClassObject.
* You really should implement OnGetPluginInfo to provide information about your plugin to VDJ.
Something more like this would be a minimum IMHO:
public:
HRESULT __stdcall OnGetPluginInfo(TVdjPluginInfo *infos);
ULONG __stdcall Release();
if (memcmp(&rclsid,&CLSID_VdjPlugin6,sizeof(GUID))==0 && memcmp(&riid,&IID_IVdjPluginBasic,sizeof(GUID))==0)
else
return CLASS_E_CLASSNOTAVAILABLE;
return NO_ERROR;
HRESULT __stdcall PluginTest::OnGetPluginInfo(TVdjPluginInfo *infos)
infos->Author=(char*)"alou83";
infos->PluginName=(char*)"PluginTest";
infos->Description=(char*)"Test Plugin";
infos->Flag=0x00;
return S_OK;
return S_OK;
ULONG __stdcall PluginTest::Release()
delete this;
geposted Sat 07 Sep 13 @ 12:19 pm
Many thanks for the correction and example.
If I understand well the use of any subclass of IVdjPlugin (e.g. IVdjPluginVideoFx ) from the SDK would work with the trial version? Could I just replace IVdjPlugin from my class with IVdjPluginVideoFx, or would I have to extend some other methods?
One other thing is that I am using DevCpp. I don t know if I am doing right or not but the projects compiles and I get the dll without error. I have a main dll file where I include my class and it looks like:
<code>
BOOL APIENTRY DllMain (HINSTANCE hInst /* Library instance handle. */ ,
DWORD reason /* Reason this function is being called. */ ,
LPVOID reserved /* Not used. */ )
switch (reason)
case DLL_PROCESS_ATTACH:
return TRUE;
break;
case DLL_PROCESS_DETACH:
break;
case DLL_THREAD_ATTACH:
break;
case DLL_THREAD_DETACH:
break;
/* Returns TRUE on success, FALSE on failure */
return TRUE;
</code>
Thanks,
Alou
<code>
switch (reason)
return TRUE;
break;
break;
break;
break;
return TRUE;
</code>
Thanks,
Alou
geposted Sat 07 Sep 13 @ 3:01 pm
Yup, change subclass, IID in entry point and implement any required methods.
Never had any success with GCC and windows VDJ due to name mangling issues.
geposted Sun 08 Sep 13 @ 6:01 am
Still not working. The plugin infos are even not showing on VDJ. I think it is deployment problem as the dll compiles without trouble. Please if someone has managed to compile a plugin in Windows using DevCpp and Mingw, help!
So far this is my class. Many thanks
#include "vdjDsp.h"
#include <stdio.h>
class PluginTest : public IVdjPluginDsp
public:
HRESULT __stdcall OnProcessSamples(short*, int, int);
HRESULT __stdcall OnStart(int, int);
if (memcmp(&rclsid,&CLSID_VdjPlugin6,sizeof(GUID))==0 && memcmp(&riid,&IID_IVdjPluginDsp,sizeof(GUID))==0)
else
return NO_ERROR;
infos->Flag=0x00;
return S_OK;
FILE * pFile;
pFile = fopen ("C:\\testje_timer.txt","a");
if (pFile!=NULL)
fclose (pFile);
return S_OK;
HRESULT __stdcall PluginTest::OnProcessSamples(short *buffer,int nb,int pos){
return 0;
HRESULT __stdcall PluginTest::OnStart(int pos,int deck) {
FILE * pFile;
if (pFile!=NULL)
fclose (pFile);
return 0;
#include "vdjDsp.h"
#include <stdio.h>
public:
else
return NO_ERROR;
infos->Flag=0x00;
return S_OK;
FILE * pFile;
if (pFile!=NULL)
fclose (pFile);
return S_OK;
return 0;
FILE * pFile;
if (pFile!=NULL)
fclose (pFile);
return 0;
geposted Sun 08 Sep 13 @ 8:41 am
C++ name mangling is compiler specific. Use the MS compiler.
geposted Mon 09 Sep 13 @ 10:36 am
It is working now after compiling with VS. Thank you guys very much.
Alou
Alou
geposted Mon 09 Sep 13 @ 6:37 pm
