I use my laptop during shows but I also use my desktop when at home,....is there anyway that I can transfer all the chache files so that both computers are the same ?, just I find it easier on my desktop to work for extended periods. Also when we get the next version of VDJ will out cache be affected ?, Could cache transfers be included in the next version.
geposted Mon 21 Oct 13 @ 4:25 am
I don't use any of the ContentUnlimited services, but I believe the cache folder is maintained inside the VirtualDJ folder in Documents.
You can use software like Dropbox to synchronise your VirtualDJ folder across both your machines. This will mean your cache folder is also maintained.
There is a thread that already details how to use Dropbox here.
You could equally use SkyDrive or Google Drive if you already have either installed.
Cheers,
Roy
Cheers,
Roy
geposted Thu 24 Oct 13 @ 12:15 pm
Thanks very much for the advice, it works sweet !!.
geposted Thu 07 Nov 13 @ 4:40 pm
No problem...
Roy
Roy
geposted Sun 10 Nov 13 @ 3:39 pm
