I've search all over the forums and maybe I'm just really bad at wording what I want in a search. Basically, I want to hook up an external monitor and display either the names of the tracks currently on both decks, the album artwork, or preferably both. I'm not sure if there's something already built in to do that or if I'd need to download a plugin.
geposted Mon 21 Oct 13 @ 11:40 am
Go to config > video tab > at bottom of page use the drop down window opposite the "use this plugin" and you have a bunch of selection options. But I think you will need to purchase pro.
geposted Mon 21 Oct 13 @ 12:00 pm
The "Titler" plugin will show name of the song automatically to the external screen.
And there are other plugins to show images, logos, coverart etc :
http://www.virtualdj.com/addons/effects.html?category=video&order=default&platform=all&search=
But as mentioned, you do need pro version for this .
You can upgrade, or get pro version here:
geposted Sat 02 Nov 13 @ 8:36 am
