It probably has bad discussed before,but would it be possible to trigger sound effects, loops, samples or automatic video transitions with the crossfader? Something like this mixer has: http://www.youtube.com/watch?v=5wQ3dbfMaNk I think it's a fantastic idea, because you can do more with your 2 hands.If its already possible to write a script for that,how would it look like?
geposted Sun 22 Dec 13 @ 9:13 pm
That should already be possible via VDJScript :)
geposted Mon 23 Dec 13 @ 5:21 am
Thank you.I will play with that and hopefully learn something about vdj script while doing it.To have it on channel faders is great too.But the whole advantage of using the crossfader for that ,is that you have your other hand free and you can play with eq,apply other effect (filter for example) or control looping (or hot cues) on incoming track.How would I say: "turn on effect1 on deckA when crossfader reaches 50%" in vdj language :) ?
geposted Mon 23 Dec 13 @ 1:28 pm
It would have to be a continuous script, (there's a pluggin you need for that)
but it should be something like,
crossfader 50% ? deck 1 effect "YOUR EFFECT" activate & deck 1 sampler play : nothing
The ? makes it a query, if it's true it does the stuff after the question mark up to the : if it isn't true it does what's after the :
geposted Mon 23 Dec 13 @ 8:13 pm
