Forum: Old versions
Topic: crackling noises on the right channel & latency problems ddjsx
sirdjPRO InfinityMember since 2007
Having some serious issues with crackling problems on the right channel and latency, platter suddenly goes really slow. I have the native mapping andlatest firmware for ddjsx and vdj.
Any ideas on how to fix this?
Thanks
geposted Fri 17 Jan 14 @ 7:23 am
Are you using 7.4.1 ?
Also where's your current latency settings ?
geposted Fri 17 Jan 14 @ 10:33 am
I don't have any settings, since I've been using the mc6000 for a long time, I never had a problem with it.
Now it's a different story with the DDJSX.
I'm also using a Rain Computer with this specs, although I don't think it has anything to do with since it meets software and hardware
2.1GHz Intel Core i3 Dual-Core
4GB of DDR3 RAM
500GB 7200rpm Hard Drive
Intel HD 2000 Graphics
15.6" Widescreen LED-Backlit Display
1366 x 768 Native Resolution
Windows 7 Home Premium (64-bit)
geposted Fri 17 Jan 14 @ 9:01 pm
ChuwitPRO (OEM)Member since 2007
Sounds like a Audio Latency Problem.
Try Increase ASIO Latency to 256 or 512
geposted Mon 20 Jan 14 @ 12:13 am
And don't use advanced soundconfig.
Everytime I use the advanced soundconfig i get crackling sound on every deck after couple of minutes.
My settings:
Input: none
Output: Master+Headphones
Soundcard: DDJ SX Asio
That way I have no problems.
geposted Mon 20 Jan 14 @ 5:02 am
Thanks for the input, I'm doing some heaving testing before I can take it live, so this will help a lot.
geposted Tue 21 Jan 14 @ 5:14 am
