Forum: Old versions
Topic: Can't get launchpad mini to work
Hi guys,
As you can see from the title, I can't get my launchpad mini to work with VJ. I've download the definitions amd mappers from this site but VJ is not detecting my launchpad. Its works fine with Ableton. My OS is Vista.
Thanks for any help.
geposted Mon 20 Jan 14 @ 4:56 pm
What definitions and mappers? I don't see any for the Mini, only the full size Launchpad.
Your Mini will have a different device ID to the full size ones. You can't just take the Launchpad mapping and have it work with the Mini.
geposted Mon 20 Jan 14 @ 6:10 pm
geposted Mon 20 Jan 14 @ 6:12 pm
i thought the definitions would be generic to the launchpad. I'll give writing one ago, see if i have any luck. I will keep you posted!
geposted Tue 21 Jan 14 @ 2:17 am
If anyone has made the definitions and mappers get them on the downloads!!!! :)
geposted Tue 21 Jan 14 @ 5:37 am
geposted Tue 21 Jan 14 @ 5:44 am
Thanks, I'll message them now.
geposted Tue 21 Jan 14 @ 8:32 am
geposted Tue 21 Jan 14 @ 9:22 am
Well done!
Now you could (with the original author's permission) upload your new Mini version mapping for others.
geposted Tue 21 Jan 14 @ 9:33 am
groovindj wrote :
Well done!
It was SuperAceMans, will have to remessage him!
geposted Tue 21 Jan 14 @ 10:08 am
djlaythem wrote :
Sovled, I downloaded this pack http://www.virtualdj.com/addons/16193/LaunchPad_S_OPD.html then found my device ID in windows device manager then entered vid="0x1235" pid="0x0036&mi" in place of what was there.
Actually the correct value for the pid should be 0036, so it should be pid="0x0036"
geposted Tue 21 Jan 14 @ 8:25 pm
Just tried that and it works. When i first tired it didn't, I must have had another error on the sheet I had hadn't corrected 1st time around!
geposted Wed 22 Jan 14 @ 4:32 am
