Forum: VirtualDJ Plugins
Topic: Database printer / search program
mrdjalPRO InfinityMember since 2009
Hello
I have tried the DB Manager but can not export
I am looking for a way to search my databases to check to see if I have the music needed for jobs.
Is there a stand alone program that will import my databases so I can search them on a PC that does not have VDJ installed.
I have 4 partions on m laptops so I have 4 databases.
I would like to have a program to read the databases and to be able to export the data to excel or access
any input would be great
Thanks
Al
geposted Tue 21 Jan 14 @ 1:45 pm
mrdjal wrote :
Hello
Thanks
Al
Hello again
does anyone have an answer to this question
looking for a clean way to export my xml file to a database
DB Manager looks like the feature is there but not finished
how much would it cost to have the export feature finished
I have seen other request about this, but no answers
Thanks
geposted Thu 03 Jul 14 @ 3:44 pm
Is there any particular reason why you don't just install VDJ and use that to search?
geposted Fri 04 Jul 14 @ 4:45 am
Yep
the reason I dont just use VDJ to do the searching is that,
I do not have VDJ setup on my home PC or work PC, plus I have 4 partitions accross 2 drives, so that gives me 4 databases to search.
I like to check to see if I have the music needed for an upcoming event, with out turning on my DJ laptop.
Plus I find it useful to be able to view a list to check for errors / typos.
Thanks for asking
Al
geposted Tue 08 Jul 14 @ 9:30 am
