Forum: Old versions
Topic: Saving your setlist via your playlist window..
I've searched all over VDJ's interface & options at the club I DJ at & STILL cant find a "direct link" to a log of the songs I've spun for that evenings event. I know about the "History" option but it seems a bit tedious to filter through. Are any other ways besides the one I came up with bellow??
Exporting your live playlist in VDJ
1. In 'VDJ', first make sure the "Playlist" window to the right is locked open.
2. Next, for every song that is cued up & is played, also drag it over to the right into the "Playlist" window.
3. After your set is finished, look for a "Plus/ +" sign (yellow) in the top left of the "Playlist" window. Click on it.
4. It now opens the "Playlist Management" window. At the bottom, choose the option to "save" then name your playlist.
5. 'VDJ' saves your playlist as a .m3u file in its default playlist directory.
Something like...
C:\Users\Documents\VirtualDJ\Playlists\
6. Now, open your saved playlist with your default music player which most likely reads .m3u/playlist files.
FINALLY, After your "Playlist" loads in your player, export the playlist to a .txt file. DONE!!
geposted Wed 29 Jan 14 @ 9:16 pm
Hello I am not really sure what your question is here. But if you are wanting your playlist and wanting to say move it to another computer here is how.
If you click on history, you find the exact date that you worked.
It will be listed something like
2014-01-28 or something like that.
You click the date.
It will show a list in the regular search location, as well as in the "playlist" area.
Click on the playlist options and save that play list. Make up a name for the playlist like Awesome Night 2014.
now minimize VDJ
Go to My documents folder
click on the Virtual DJ folder
Click on the Playlist folder
find "awesome Night 2014.m3U"
highlight it then copy it.
go to a flash drive and paste it there.
then go to say another computer and reverse the steps and copy the file from your flash drive and paste it in its respected folder on another machine.
I hope that helps.
Instead of having to copy it to a playlist, you can go to the 'tracklisting' folder. All of your history .m3u files are there. You can copy and paste them into the file folder of the same name on your second machine as well. This way, the history files remain in your history section instead of moving them to your playlist section in vdj.
