Forum: Old versions
Topic: Mixtrack Pro 2 - Mapping effects
Hey guys
I know this sounds dumb... but it's been driving me nuts. Everything is working perfectly, but I cannot seem to map the effects on my Mixtrack Pro 2
I know there is an easy way to do this... anyone??
geposted Mon 10 Mar 14 @ 10:42 pm
effect slider 1
effect button 1
effect active
the numbers can be changed to control different sliders and buttons.
thank you!!!
just one more question, the 4th effect button on top... what does it do? lol it says its a "tap" ?
It's a bpm tap.. I would remove it so you don't mess up your beatgrids my mistake once set
