It would be nice to be able to create a venue for every club you Karaoke in and add names of singers to that venue and their song choices. Check out kjams software, it works really well, however kjams is only a karaoke player.
I also would like to see plugins work on the Mac like when I'm playing a audio only song, I'd like to be able to play a video of something along with it.
geposted Mon 24 Mar 14 @ 12:19 am
This could be a fantastic addition to the Karaoke plugin.
but until they update the plugin, you could use the virtual folders to accomplish the same results..
first create a folder called Karaoke requests, then create another folder inside this with your first venue name, then a third folder within the venue for each singers name..
it seems like a bit of hard work to set this up but after a few weeks you will see the advantage of doin this in this way..
geposted Wed 26 Mar 14 @ 6:10 pm
Yes their is work needed to be done on the karaoke side, i requested they do these things in vdj8 so we will have to see.
geposted Wed 02 Apr 14 @ 1:29 pm
