I get a coreaudio error message every time i try to set up the sound setup to "advance config" and using the MC6000 soundcard. I know this is possible on a PC, can it be done on a MAC?
The reason being, I want to add a "Line In" and using my Macbook pro on board microphone to display a rhythm wave display and BPM display on the deck. I want my mic to listen to another dj spinning next to me and display the wave, then i can sync and beat match to his music. As far as I know this is only possible when setting up the sound setting as "advance config". if you guys know of any other way, i am all ears.
Thanks.
zerosn10
Thanks.
zerosn10
geposted Wed 09 Apr 14 @ 12:24 pm
I'm sorry but the ADV config does not work while using the MC6000 AND the Mac version.
I'm sure this will be fixed with V8.
And no, i do not know when V8 will be released :-)
geposted Wed 09 Apr 14 @ 2:07 pm
