Forum: Old versions
Topic: Keyboard command help (my brain mustn't be working)
effect "Echo" slider 1 0% ? effect "Echo" slider 1 1.0% : effect "Echo" slider 1 -0.1%
I use the echo effect more as a delay, but at 0% it flattens the sound lower even than there being no effect, so I want it to jump up to 1% or something like that when I get to 0% (actually it will be when it gets to 0.1%) (it will actually be even more complicated than this but I haven't decide what I want)
It currently minus' 0.1% but it won't jump back upto 1% when I want it to.
geposted Wed 16 Apr 14 @ 3:50 pm
I think I don't really get what you are trying to achieve, but have you tried playing around with the "param_equal" verb?
Sth. like this maybe:
effect "Echo" & param_equal 0% ? slider 1 1% : slider 1 -0.1%
This should be mapped to the slider encoder.
geposted Thu 17 Apr 14 @ 1:32 am
maybe something like...
effect select 'echo' & effect slider 1 & param_cast 'percentage' & param_smaller 2% ? effect slider 1 1% : effect slider 1
not sure if it'll work, and haven't tested it.
geposted Thu 17 Apr 14 @ 2:28 am
I think param casting isn't necessary here.
At least, that is how I understand the Wiki:
param_equal : check if the value of the calling slider/encoder/button is equal to something: 'param_equal 50% ? key_lock off : pitch'
geposted Thu 17 Apr 14 @ 3:33 am
Your absolutely correct.. Sorry brain fart ;-)
param_smaller 2% ? effect 'echo' slider 1 1% : effect 'echo' slider 1
that's all you need.
geposted Thu 17 Apr 14 @ 3:51 am
I couldn't get either of those to work, but I'm not great at reading between the lines with syntax
I do something similar with the deck levels with no problem
deck 1 level 0% ? deck 1 level 100% : deck 1 level -3.33%
this button drops the volume level but if volume is at 0% it jumps back up to 100% so it is a little like a jog wheel
What I essentially trying for is a button that drops the echo slider 1 upto the point of 0.1% if I press the the button further then the slider jumps upto a higher level (or the effect turns off)
I'll try again using the main effect *edit still no joy.
geposted Thu 17 Apr 14 @ 5:46 am
the second one I wrote was for an absolute fader/knob.. maybe this:
effect select 'echo' & effect slider 1 0% ? effect slider 1 100% : effect slider 1 -2.5%
if you use 3.33 it won't ever reach 0
geposted Thu 17 Apr 14 @ 5:59 am
Nope still no joy, I think I may have to abandon the idea, perhaps completely familiarise myself to what 0.1% echo sounds like so I don't go under, or maybe skin a blinking warning light to come on when echo = 0.1% (I've skinned similar warnings on the filter before [!=50%] because it kept catching me out)
geposted Thu 17 Apr 14 @ 6:22 am
what do you use, a keyboard, a controler...?
You want this mapper for un knob, a slider, a fader?
juan
geposted Sun 20 Apr 14 @ 10:30 pm
Laptop keyboard, one key, Like I said I had a similar thing working with the deck levels (one key brings the volume level down until it gets to 0% and then it jumps up to 100%) but it doesn't seem to work the same way for an effect slider, (or I made a typo but I don't think I did)
geposted Mon 21 Apr 14 @ 11:31 am
