Greetings all,
I am looking for some configuration assistance. I recently had Virtual Dj configured to work with my 2 SC3900 and a Pioneer DJM600 mixer and it was working great. The only downside was I could not control volume sliders, etc via the DJM600 so I decided to purchase a X1600 mixer. I am trying now to get it working and I have having some problems. So far, I have been able to config VDJ to use the X1600 soundcard in advanced config mode with channel 1/2 for deck 1 and channel 3/4 for deck 2 and the SC3900 as controllers. It works find on deck 1 (ie I can navigate, load a song, and play/control the song) but I cannot get it working for deck 2. Can someone please direct me to any previous config directions that I can use to troubleshoot my problems and get it working correctly. Thanks so much.
Keith
Keith
geposted Sat 19 Apr 14 @ 1:45 pm
Bump
geposted Wed 23 Apr 14 @ 5:11 pm
Download Skins Link....???
geposted Thu 24 Apr 14 @ 6:16 pm
A) Your post has absolutely nothing to do with the topic being discussed in this thread.
B) You need to be a registered VDJ Pro licenced user to download & use skins.
geposted Thu 24 Apr 14 @ 6:19 pm
To the OP:
* Check that both SC3900s are set to MIDI Channel 1 in their settings (Hold MEMO etc)
* Check that in the VDJ config > mappers > mappers options that both SC3900s are set to control an actual numbered deck rather than 'default' or the same number.
geposted Sat 26 Apr 14 @ 7:07 am
