Forum: Old versions
Topic: Pioneer DDJ-SZ Support
geposted Tue 22 Apr 14 @ 6:42 pm
On the wiki page, you have your images mixed up (2 decks, 4 decks) and there is a spelling mistake:
"depending on your Operating system ans the decks you need to use"
Fixed. Thanks. [djdad]
Good ;-)
Pioneer DDJ-SZ native mapping files for version 8 have been updated.
Dont use the links above, those are for version 7.
You will need to update to build 1845.693 or higher.
Important. You will need now to switch the unit to the Serato mode. Read the manual of the unit (UTILITES mode) on how to do that.
- All Rings leds supported
Outter (4 white-blue leds) flashing when song reaches end
Inner large. Proper rotation following the rotation of the software wheel
Inner small (red), showing the loop progress
- Minor changes in the Pads mode to follow mapping consistency with DDJ-SX and other DDJ series mappings
- Trigger mode for Hotcues (same as Serato), changing from SHIFt+PRM buttons on HOTCUe mode
Side note
For those who use 4 decks, and build 1855 (not public yet), map the pitch slider as pitch 'dual'. This change will be available in the default mapping files once build 1855 becomes public.
DDJ SZ sound setup with virtual DJ7 do you have to use the advance audio config or can you use the external mixer setup, if you don't need the record loopback and are only using 2 decks.
If you dont need the RecordLoopback, and only use 2 decks, then yes you can still use the Simple Sound Setup with External mixer and the Pioneer ASIO.
Thank you
I wanna ask two things: since the DDJ-SZ is originally mapped for serato, is there any function that cannot be performed on virtual dj? I just went through the manual and it seems ok but wanna make sure. Also, anyone know if the jogwheel response for scratching is similar for both software when using this controller? I got my eye on this hardware and wanna identify any limitations since I'm a VDJ user. cheers !
No, there is nothing on the unit that cannot be operational. Of course each software has its own way of doing things and its own features, so there will be difference but nothing to do with the functionality of the unit.
There is no known issue or buggy behavior at the moment. The only thing that you may notice (if you take a good look at the rotation ring),is that its not that smooth as it should. But i suppose this wont impact the functionality at all.
I cannot find some infos about the DDJ-SX with VDJ 8. Does anybody have a link to a thread or something (skins, etc.)?
Thanks!!
