Forum: Old versions
Topic: mapping for gemini firstmix pro
how can i get mapping for a gemini firstmix pro
geposted Tue 29 Apr 14 @ 8:19 pm
As you can see from the list of supported controllers here or under the mapping tab of the config area in VDJ, the FirstMix Pro is not a natively supported controller.
You can also see from the controller mapping download area that there are no user mappings either. Consequently, the only way to map it would be to do it yourself. It might be worth using the existing FirstMix mapping as a guide/starting point.
could you please provide me with the step by step procedure for mapping my Firstmix pro with the virtual DJ.
Thanks.
Mike
