I've had enough of Native Instruments Traktor Scratch, Native Instruments software has always been bug riddled and a problem, anyway, I want to use timecoded vinyl in Vurtual DJ 7 Pro, is the program compatible with the Denon DN-X1600 with timecoded vinyl use? If so how do I set it up and are there any problems which people might be or I personally might encounter?
geposted Sat 03 May 14 @ 2:48 am
You will need to register your pro version, for time code. You can look here for setup help.
geposted Sun 04 May 14 @ 12:54 am
