Topic: Pitch Issues [SOLVED - autoBPMRange]
Everytime I load a song, the pitch is automatically synced with the other track, Cannot find a setting to fix this. Thoughts?
geposted Sun 11 May 14 @ 11:59 am
Open config, go to options:
Select Advanced checkbox
Search "autoBPMRange"
change to No.
geposted Sun 11 May 14 @ 12:01 pm
Actually the setting you want is: autoBPMMatch
geposted Sun 11 May 14 @ 12:02 pm
Actually it's "AutoBPMMatch" that needs to turn it off
So, on the settings window just search for "BPM" and turn off autobpmmatch
geposted Sun 11 May 14 @ 12:03 pm
That Did not fix the problem, It is making me fix each individual song to the neutral point. Does not do it on all songs but most of them....
geposted Sun 11 May 14 @ 12:05 pm
Thanks that took care of it
geposted Sun 11 May 14 @ 12:06 pm
kool, i was looking for that fix..
geposted Thu 15 May 14 @ 9:48 am
